JayFox
Aug 27, 2019Aspirant
New Orbi AC 2200 Satelllite Slow
I have Xfinity 400mbps service and just purchased the Orbi mesh system to get wifi in my garage. My speed near the modem/router combo is at about 100mbps, and out in the garage using a satellite at the halfway point (approximately 12 yards from the modem) is only 30mbps. This feels really weak, anyone have a suggestion as to what might be going wrong?
JayFox
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.Whats the building materians comprised of?
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
