dkunath
Jan 17, 2018Star
New Orbi firmware 2.1.2.18 update issues?
I noticed that there was a new firmware version 2.1.2.18 for Orbi RBK50. Has anyone installed this version, and has there been any issues after the installation. Please provide any details that you...
mealto
Feb 12, 2018Star
How do I disable auto firmware update after going back to 2.0.0.74?
PyroDog
Feb 12, 2018Apprentice
That used to be a method known to block auto updates. It no longer seems to work. I'm lucky enough to be running Orbi in AP mode behind a proper router with firewall capability. I'm blocking all traffic generated by the Orbi units.
- SteveBalaFeb 12, 2018Star
wrote:That used to be a method known to block auto updates. It no longer seems to work. I'm lucky enough to be running Orbi in AP mode behind a proper router with firewall capability. I'm blocking all traffic generated by the Orbi units.
+1
Added Block ALL from Orbi Router and Satellite to WAN traffic on my upstream checkpoint firewall. Now it' stuck on .74 firmware.
- heyeaglefnFeb 13, 2018Guide
So outside of using it in AP Mode and block traffic with another router, there is no way to block the auto update since Telenet doesn't work anymore.
- PyroDogFeb 13, 2018Apprentice
wrote:So outside of using it in AP Mode and block traffic with another router, there is no way to block the auto update since Telenet doesn't work anymore.
As far as we know that is the current situation.
