iarsenal85
Jul 30, 2018Aspirant
New Orbi RBK50 - Suggested Firmware and Settings
Hey guys,
What suggestions do you have on what firmware to run to minimize any issues? Any specific settings?
Thanks!
Jul 30, 2018Guru - Experienced User
I set up my friends 50 series using this process:
What is the Mfr and model# of the ISP modem the Orbi is connected too?
Any network LAN switches in the mix? if so, what is the Mfr and model of the switch?
- iarsenal85Jul 30, 2018Aspirant
I will double check on the cable modem model, but it is a Spectrum setup cable modem 3.1 docsis no wifi cabapilities. No switches in between. This is replacing my Cisco 1602e setup.
