tomtendo
Mar 01, 2019Aspirant
New Orbi RBK50, but Upload Speeds are slower than before?
I just installed our new orbi rbk50 and while download speeds are fine... my upload speeds are half what they use to be on my airport extreme... what gives????? Do I really have to return this?
- tomtendoAspirant
Previously, I would get 280-300 download and 15-25 upload via Wifi....
Now I am getting the same download, but 6-9 Upload via Orbi Wifi.
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
Are these speed results wired or wireless?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- tomtendoAspirant
Firmware is the latest one. I checked for new several times. V2.2.1.210
My modem is a Surfboard SB6183, Arris.
No idea if in router or AP mode. How can I tell? I never was asked this.
House is 3400sf. Signal isn't an issue right now. Upload speed is.
I would say the Satelittle is about 30 feet away, upstairs (Modem is downstairs).
WPA is "WPA2-PSK [AES]"
Not sure what you mean or where for "
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s)."- tomtendoAspirant
It's in Router mode.
