andykerslake
Feb 06, 2017Star
New Orbi Setup now no disconnects on iPad and other devices
I have just installed a new orbi setup with router and 1 x satellite.
I struggled for 2 days trying to work out why some devices iPad 2 and an Android Phone were disconnecting on a very regular basis.
Eventually I reduced the 2.4ghz band transmit power to 25%, this has fixed all of the disconnects. 5.0ghz is set to 100%. Also currently beam forming and mu-mimo are turned off.
Previously I was using an Asus router with dual band wifi, but the bands had different SSIDs. I think the fact that the Orbi has a single SSID is causing some devices to disconnect due to the competing signals.
I am very familiar with wifi systems having installed simple access points and enterprise wide systems at our customers, and my reason for using Orbi was to look at a possible new solution for our customers.
- DarrenMSr. NETGEAR Moderator
Hello andykerslake
Thanks for sharing these tips on what is working for you.
DarrenM
- SlykeGuide
Did that fixed your problem? I am experiencing the same problem as you described, sudden and regular disconnection on some of the ipad at home. Other devices seem to work with no problem but I ADS are suddenly disconnected (I have even the latest version)
Thank for the feedback you can provide me
Yes it did fix all the disconnects. The problem only affected Apple devices.
I have not tried turning back on the 2.4Ghz as the current setup works, and I do not need that band.
Andy
- At Slyke, for your devices that have stable connections, could they be connected to the router instead?
For me, my Satellite-wired clients died and this confirmed the Satellite was essentially out. - Retired_Member1. False
2. Not related to the problem
3. Not related to the problem
The backhaul connection from the router to the satellite is dropping which means every device connected to the satellite is technically dropping but is usually only noticed on iPads or sensitive devices like cameras and Wi-Fi calling. The problem is with the router and not the satellite and definitely not the end points.- tallacknGuide
Apologies BobertSagnet, my reply was related to Slyke's last post. It does not thread so well on here. I am not sure how it would relate to a problem you may have.
What we are focusing upon with those questions from Slyke is the likelyhood that the iOS devices are not roaming to the router when the satellite drops the client network when its backhaul goes down.
Given the proximity of the router and the satellite there is likely coverage overlap for the client networks and it is possible that the non-iOS devices are seamlessly roaming to the router when the satellite fails.
That is where my questions were focused.
- Retired_MemberGot it, sorry about that I was only focusing on the backhaul but I'm glad you guys are taking it a step further to see how devices respond to that differently.
Quick thought that might relate, do you notice the the same speed all the time whenever you run a Speedtest on any of your devices? The backhaul drops it's 5 and 2.4 GHz signal at different rates and I wonder if non iOS devices are better at switching from one to the other instead of switching completely to the router and noticeably dropping. I will go from 230 Mbps to 50 Mbps on my android with no explanation.- tallacknGuide
Yeah, that is related to band steering.
When your endpoint is trying to associate to the SSID, the AP will supress the responses on 2.4GHz for a bit hoping the endpoint will give up and move to the 5GHz band, where it will answer and allow association. If it never hears the endpoint on 5GHz then it will respond on 2.4GHz. In this way endpoints that support both bands will be "steered" towards 5GHz.
The reason for this is 5GHz has a whole lot more channel space. The AP can operate a 160MHz wide channel up in the UNII-1 channel space that is more often than not free of significant noise. That way it can get multiple spatial streams at nice high symbol rates and get that nice fast speed you are doing.
But when your endpoint cannot associate to the 5GHz radio, perhaps because the signal is too weak (5HGz does not penetrate obsticals in the home as effectivly as 2.4GHz does) then you are going to end up on a 20MHz wide 802.11n channel on the 2.4GHz radio. Lower symbol rates, likely single spatial stream (because the additional paths are too weak), hence your lower speeds.
Some endpoints do not bandsteer so well, so they may end up "sticking" to 2.4GHz after you move away from the AP (out of range of the 5GHz coverage) and then remaining on it when you walk close to the AP again. You can see this is the case if you are in the same room as the AP and associated at lower speed, turn off the endpoint wireless adapter for a few seconds, turn it back on again, and you will likely reassociate to the 5GHz radio.
Some endpoints don't need to be band steered, and will always "preferr" 5GHz, always trying to use it first, and always trying to get back onto it at regular intervals. This is true for iOS devices, so you may see these suffering less from the "stickiness" that other non-iOS endpoints do.
Honestly, I could prattle on for HOURS about this stuff if you let me. You'd think doing this as my day job would satisify my appetite for it, but it does not. I love this stuff. And I love this Netgear kit. Honestly, for a consumer product, this kit is amazing!
- MrTonyTocaApprentice
I am having Wifi connection drop outs on my Galaxy S8+ Android phone. I have 1 Orbi router Ac3000 and 2 Ac3000 Satellites. 1 on each floor. satellite in basement. router on main floor and satellite on 2nd floor. I know this is over kill as my house is only about 1800 sq ft. But I needed the ethernet ports on each floor as I have a movie theater in basement and an extensive gaming setup on 2nd floor. Is my problem overlapping? Should I try and move my satellites farther away from my router? the new firmware removed that ability to turn down the wifi signal strength (25%,50%,75%) it has been replaced with threshold and some odd numbers. I love orbi and it was working amazing until I added my 2nd Satellite. which worked fine for 2 weeks and now I cant stay connected via my Android phone for more than 5 minutes. Please give me some suggestions. Ive tried turning beamforming off and mu-mimo and even disabling 2.4ghz band. still disconnects. is there a way to maintain the ethernet port capability of the satellites but turn off the wifi signal so I just use the router for my wifi signal and the satellites just for the ethernet connection? Thanks
