JoshBear
May 01, 2018Aspirant
New user problems
Hi all
i was using the BT whole home mesh network through 6 disks but unfortunately after a poor firmware release it became unstable dropping connection every few mins. This makes working from home almost impossible. So I bought the Orbi and an extra satellite. Using the test part of the app I get 35mbs download and 10mbs upload over a property of 5000 square feet.
Howver over the past 24 hours I keep getting drop outs where the fan symbol still shows on the iPad and iPhone but safari doesn’t load. Speed test won’t load either. Tonight I am in bed and had to tether to my iPhone even though there is a full fan icon in here.
Anyideas what what could be the cause?
Thanks
josh
What Mfr and model # ISP modem do you have?
What FW version is currently loaded on the router and satellite?
What is the distance between the router and satelllite? Feet?
Try setting manual channel 1, 6 or 11 on 2.4ghz and any unused channel on 5Ghz.
Try disabling Beamforming, MIMO, Daisy Chaing and Fast Roaming and see what happens...
- JoshBearAspirant
Hi
Thanks for the response
What Mfr and model # ISP modem do you have? - BT Smarthub latest version
What FW version is currently loaded on the router and satellite? router 2.1.4.10. satelite the same
What is the distance between the router and satelllite? Feet? router and sat 1 5 feet but two walls. sat 2 is the next floor upand maybe 10 feet away
I havent tried these yet but have only just realised that it should been set to AP mode which I have done. Will give this a go for 24 hours to see if issues go away.
thanks
Ok, let us know how it goes.
Ya if your ISP modem has a built in router then one option is to use the Orbi in AP mode.
Try setting 2.4Ghz channel to manual channel 1, 6 or 11.
