Cynomus
Apr 16, 2018Guide
Nighthawks as a Orbi Satellites
Dear Netgear,
I have a couple Nighthawks R6220 and R7000, now I have an Orbi AC3000. I paid as much for the Nighthawks as the Orbi system. Please consider releasing firmware updates that allow Nighthawks and Orbi units to function together as a mesh, rather than a mesh and 2 disjunct WAPs, connected only at a VLAN level. Even if the backhaul could only go over the CAT6 interconnect, rather than wireless. I suspect, you are mostly interested in simply selling more high dollar units, but consider being loyal to your loyal customers, who already have invested heavily in your gear. (Including thousands in storage devices, and switches).
Nighthawk routers don't suppot MESH systems or have the abilities to operate like Satellites. HW is different as well. NG probably isn't going to allow such configurations since the Orbi systems are a specifc design and intent as well as Nighthawk routers are specifc for there design and intent.
You can use your Routers as APs, LAN to LAN, they would just need to be on separate channels far apart from what the Orbi is using.
- CynomusGuide
I understand they are different systems, I'm an engineer, however, I also understand that good code could still allow them to at least handle handing off clients between units in a coordinated manner. Further it would encourage existing customers to NOT considering purchasing other competing products from other vendors, when considering a new mesh wifi.
Well maybe a nice idea, however im sure there is specifi reasons why NG may not do that. The Orbi systems are specifcally designed to work with there HW. Im sure also NG may not want to bother there product lines as well. I presume NG may want to keep there way of doing things, good or bad or indifferent, the way see see fit. Been doing this a while though. Anything is possible. Wouldn't happen any time soon though.
