fsa317
Nov 21, 2020Aspirant
No devices connecting to satellite
Been trying to improve my setup. I had my Orbi in my basement but moved it to a new setup that is like this.
In my basement's "back room" is my fios router. Hardwired from there is an 8 port switch which feeds a hardwired location on my second floor. THis is where I have my RBR40 plugged in and setup in AP mode. This is working great. The switch also feeds another hardwired location in the opposite corner of the house in the basement where I have an RBS20 satelite that I have hardwired to the ethernet. In the Orbi tool I can see the RBS20 as a satelite and wired with backhaul good. However, nothing connects to that satelite even when I'm next to it in the basement. I'm not sure if that is because it is hardwired but not directly to the RBR40, but its showing up as a satelite.
One other thing I noticed is that when I connect to orbi via a webrowser the satelite looks to be connected, but via the app it doesn't show the satellite as healthy.
THoughts
Be sure the RBS are connected behind the RBR:
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System- fsa317Aspirant
The switch is this one:
https://www.amazon.com/gp/product/B00KFD0SYK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
What do you mean by behind? Right now its basically router --> swtich and then the switch has hardwired connections to both the RBR40 and RBS.
ALL ethernet RBS connection have to be connected at the RBR, not at the main host router or ISP modem/router.
Review the link on where the RBS are connected...
