mrputtputt's avatar
May 02, 2018
No easy way to turn off router and satelitte wifi
Model - RBR50
Firmware - V2.1.4.10
App version - 2.1.2.313 (for mobile), else using IP# thru Windows 10 laptop
OS - windows 10 PC
How to I turn off the router's wifi and the satellite's wifi and only use ethernet hardwire? I already updated the firmwares for both router and satellite. Orbi GUI shows the the satellite is already connected via ethernet backhaul.
Searching thru community posts, it seems like I'd have to telnet in to do it? No easy way via GUI?
  • FURRYe38's avatar
    You can disable the wireless radios on the router under Advanced/Advanced Settings/Wireless.
    Uncheck Enable SSID Broadcast. NOt sure if the Satellite can be done the same way. The satellite may have wifi always on.
    • mrputtputt's avatar
      mrputtputt
      Tutor
      disabling SSID brodcast does not turn off WIFI. That just stops the SSID from showing up in lists if you're trying to find a WIFI. I came from an Asus router, and disabled SSID. But my wifi devices still connect because it's already established. SSID broadcast just means "hey, I'm here for you to connect."
  • You can't turn off WIFi via the GUI.  There is a post on here describing how to temporarily disable a client radio via telnet, but I don't think the setting will persist after a reboot.
    If you don't want to use Wifi, then I don't think you need an Orbi.  Just buy a gigabit switch to replace the satellite and add a cheap router.
      mrputtputt
      Tutor
      that is true. but it was already purchased to get a new router and replace a really old one.
      In hindsight, should've just bought a nighthawk. But part on sale and part paid with gift cards.
