PaoloWang
May 30, 2021Aspirant
No Internet connection from one RBS50
Hi guys:
Need your help for the RBS50 issue, home network set up by one RBR50 with two RBS50 by the latest firmware. Last week, one RBS50 has the issue which cannot connect the RBR50 with sync failed, and it's light show the white breathing per two or three second. I failed to sync this satelite to RBR 50 twice, even restart and delete the RBS50 in the console. Finally I saw it as the IP Address 192.168.1.250 status in the system, then I leave it to think about next step. About two hours later, the whole network was stuck for a while, then I saw this RBS synced and connect to RBR with successful status automatically. But every device which connected this RBS50 cannot visit internet, the status interface show no issue at the main console website. Go to the Firmware checking, error information show "no internet connection" for this RBS50. Although wired the router or reset the RBS50, this satelite cannot return well.
Appreciated for your suggestion or advise.
What Firmware version is currently loaded on the RBR and RBS?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
PaoloWang wrote:Hi guys:
- PaoloWangAspirant
--V2.7.2.104
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?--- TWO RBS50 sateltes connected with RBR50 by the same configuration go through Netgear GS316 switch.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.--- Using Wired connected between RBR and RBS to set up the home network
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? There shold be a ISP Modem or ONT where you get your serice from or is there just a wall jack?
Is the Orib in router or AP mode?
Is this GS316 switch before the RBR or after the RBR? Has this been factory reset or powered OFF then back ON?
- PaoloWangAspirant
Follow the steps which you forward, still failed to recover. I have two RBS50 satelite with same default configuration, one is working well and another has this issue.
