Wizeguy123's avatar
Wizeguy123
Novice - Setting up VPN on router - Orbi RBR50
I'm a novice at this, so any help would be appreciated.
Goal:  I want to disguise my IP address when streaming movies.  I can easily do this for this my desktop or phone using the VPN in my Norton antivirus.  However, I assume when I cast to a google chromecast, the chromecast doesn't have a VPN and my true ip address will be visible.  I need the router to use the VPN so that all devices connected to the router disguise the IP address.
Configuration:
- Desktop connected via ethernet to the Orbi RBR50 home unit
- Several devices including Wi-Fi only Andriod tablets and chromecasts connect to the Wi-Fi
<edited to add> - Orbi is connected via ethernet to an xfinity cable modem.
Steps so far:
- I signed up for No-IP.com and set up a host name for dynamic DNS service
- I selected Yes to Use Dynamic DNS Service in Netgear software; status shows "Updated Successfully", so I guess this is working.  Not sure how else to test.
- I signed up for IPVanish and set up OpenVP; It seems to work for the desktop, if I select a different city, and check my IP address, it shows as that city.
- I enabled VPN service in Netgear Software
- I selected, "Use VPN for all sites on the internet and home network"
- I used the Netgear software to create a configuration package, which I transferred into the OpenVP config file
- I changed the TAP-Windows on my desktop setup to "NETGEAR-VPN" - - -  This might be the issue, since the TAP status is "Network cable unplugged".  The desktop is connected via ethernet, so the Ethernet status shows "Network 2"
- I thought all would be working now.  But when I check the IP address from a wi-fi only device, it still shows my local IP address.
What steps can I take so that my wi-fi devices show the same disguised VPN IP address as my desktop?  Thanks in advance.
  • CrimpOn's avatar
    CrimpOn
    Alas, there are two parts to a Virtual Private Network (VPN)
    • The VPN Host, which accepts connects from Clients and sets up an encrypted "tunnel" between them, which effectively shields traffic from inspection and hides the Client IP address.
    • The VPN Client, many of which connect to a Host.
    Netgear bundles OpenVPN Host software with Nighthawk and Orbi routers so that customers can connect to their home Local Area Network (LAN) when away.  Netgear does not include a VPN Client capability with any of their home routers.
    One solution would be to install a third party firmware which includes this capability.  A programmer has written firmware for some Netgear systems, including the RBK50:
    https://www.snbforums.com/threads/custom-firmware-build-for-orbi-rbk50-rbk53-rbr50-rbs50-v-9-2-5-2-35sf-hw.90954/
    Another solution would be to install an appliance on the LAN which provides VPN Client capability, such as the GL-iNet
    MT2500:
    https://www.gl-inet.com/products/gl-mt2500/
    or a similar product from Firewalla.
    Perhaps I am mistaken..... How does "casting" video to televisions "work"? i.e.
    • Does the user somehow bring up a menu on the device connected to the television and tell it which video to seek?
      (In this case, it's pretty obvious that the source IP address will be the public IP of the customer router.) ... or
    • Does the user device "cast" the video stream fo the device, which passes it to the television.
      (In that case, it would seem that installing a VPN on the user device would fulfill the requirement.)
    • Wizeguy123's avatar
      Wizeguy123
      My understanding of casting via chromecast is that when you cast a media stream, what you pass on to Chromecast is the data about the media source. Chromecast then streams the media directly from the source without passing through your desktop or phone. Therefore, the VPN on your desktop or phone will not shield the Chromecast IP address.  Since the Chromecast is connected to my wifi, I assume the ip address will be mine.
