JBick
Sep 07, 2025Follower
Occassional Internet Loss - RBR20
I am trying to track down a nuisance connectivity issue. I occasionally encounter loss of connection for typically a few seconds (1 - 20 seconds). Normally this wouldn't be an issue, however it's a...
Sep 08, 2025Guru - Experienced User
ATT tends to use gateway devices that are modem/router combo devices. It causes a double nat. Check into fixing that first.
Then, power off the satellites and see if the drops happen if the computer is directly connected to the RBR and not the satellites. If it stays solid, it could be a satellite or backhaul issue.
