Mgomez85's avatar
Mgomez85
Apprentice
Aug 27, 2017
Ok I gave in
I couldn't do it no more! My sat unit for the life of me just won't keep a constant throughout put my data stream just keep dipping!! I have full cover throughout my entire house so that's great but for the life of me I couldn't deal with the constant buffering from music streaming or video playback, and the band steering seems to be struggling to keep my devices on a proper band my devices seems to be switching back and fourth btw 2.4 and 5ghz especially my iPhone I pay attention to my signal icon funny part about this story is my router unit performs flawless!!! 😑😩 so yea I added back my Netgear ex6200 extender to my network cause I couldn't deal with the dipping in the data! 😩
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Believe85
    Did you make sure beamforming was enabled? also did you try to uncheck the 20/40mhz option I know Iphones do not like to work well with the 40mhz.
    DarrenM
    • spinkick's avatar
      spinkick
      Apprentice
      I thought unchecking the 20/40 mode would force it into 40 mhz mode?
      • spinkick's avatar
        spinkick
        Apprentice
        Just looked. You want to "uncheck" 20/40 coexistence mode to take it off of 40mhz on 2.4 ghz. CHECK the box if you want 20 mhz compatibility.
