CR-sound
Jun 02, 2021Aspirant
Only some devices with DNS problems
This may be a little different than the current DNS issues discussed...or maybe not. Most of my devices are connecting with no problem (3 Windows 10 computers, a Windows 2012 Server , 4 android phones, lots of smart home devices, couple tablets). Yesterday, I turned on 4 Windows machines that had been on the network before, but were off. They would not connect, DNS server not responding. This was the case whether connected via Wifi or Ethernet. I could connect with the Wifi from the Comcast /Xfinity cable box/router. I prefer, of course to connect to my Orbi mesh network. Seems odd that some machines connect, some don't.
Orbi firmware v2.7.2.104...and btw, I have checked several times this AM and the Orbi app (android) was unable to tell me whether new firmware was available, "There was a problem checking the firmware."
What mode is your modem working in? Router or Bridge?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopYou can manully update FW to the RBW if it needs to be udpated.
- CR-soundAspirant
BTW: I did reboot the router.
Has both RBR and ISP modem/ONT been powered OFF for 30 seconds then back ON with the ISP modem first, then RBR?
Does checing FW updates on the RBRs web page show anything?
- CR-soundAspirant
Checked from the desktop access. I have 2 RBS 50s and an RBS50Y (outdoor satellite) with no firmware updates required. The RBR50 shows no firmware update available. The RBW30 satellite has current firmware of v.2.5.0.4 and shows update failed. The units I was unable to get DNS on were connecting via an RBS50 trying both wifi and ethernet.
BTW: the units with the DNS issues connect to the local network and server domain with no problem.
I have not recyled the Comcast router; they list it as Technicolor CGM4140COM.
RBR50 settings include allowing new devices to connect.
Couple of options,
CR-sound wrote:Yesterday, I turned on 4 Windows machines that had been on the network before, but were off. They would not connect, DNS server not responding.
You've probably already checked, but:
- These 4 Windows computers were on the Orbi network previously?
- Their IPv4 properties say to get IP address, subnet mask, gateway, and DNS server using DHCP?
- What does the command ipconfig /all report for the ethernet and the WiFi interfaces?
(obviously one at a time, depending on how they are connected.)
