KoodGarma's avatar
Apr 26, 2018
Open port setup on RBK50 for Qustodio and multiple iPhones
I need help to use Qustodio on both of my children's iPhones because they
won't connect to Qustodio VPN service when their phones are connected to our
Netgear Orbi WiFi System.
I've read a few articles that I need to open ports 500 and 4500. However,
Port Forwarding only let's me open up those ports for one IP address that a
phone is assigned to. It won't let me do that for both of their phone's
assigned IP addresses.
I also read that Port Triggering was an option to open the ports for "any"
IP addresses, but when I go to the configuration window for that service, I
do not know what to enter for the following fields:
Service Name: "Qustodio" (I'd just create this service name for reference)
Service User: "Any" (drop down options: "Any" or "Single Address")
Service Type: "UDP" (drop down options: "TCP" or "UDP")
Triggering Port: ??? (not sure which port # to enter in this field)
Inbound Connection
Connection Type: UDP (drop down options: "TCP/UDP" or "TCP" or "UDP")
Starting Port: ??? (field range 1~65535)
Ending Port: ??? (field range 1~65535)
I appreciate you helping me figure this out. Thank you
PS:  Please don't say to contact Qustodio cause I already tried and their customer service replied:
"In this case I would recommend that you open the 500 and 4500 UDP ports, used by Qustodio’s VPN. For additional help I recommend you contact the support for the router manufacturer"
  • I'm not familiar with Qustodio, but I am very familiar with VPNs. Normally VPNs involve your devices initiating a connection to a server on the Internet, outside your home network. In that case no port forwarding is required on your router.  If your kids' phones are initiating an outgoing connection to a Qustodio server then you shouldn't need to open any ports on your router.
    Also, as you noted, incoming port forwarding only works for one IP address, so if it was required, which I doubt, you would only be able to use Qustudio with one device on your home network.
    I don't have your answer, but I'm pretty certain you are barking up the wrong tree looking at port forwarding.
    • KoodGarma's avatar
      KoodGarma
      Guide
      Thank you -- Maybe not Port Forwarding, but what about Port Triggering?
      • st_shaw's avatar
        st_shaw
        Master
        Shouldn't need triggering either.  Normally the router will allow outoging connections on ports 500 and 4500 (or any port) with no configuration.
        If you have other devices on the network using those ports, maybe via UPNP, that can cause issues.
        Also, if your Orbi is connected behind another router, or in DMZ mode behind certain routers, then this can block VPN.  See this thread:
        https://community.netgear.com/t5/Orbi/Connecting-to-a-external-VPN/m-p/1483418
        How is your Orbi connected to the Internet?  Is it behind modem or router? What's the make and model?
