rrh770's avatar
rrh770
Optimal Settings for Orbi RBR 40 with ATT Fiber and Direct TV
I am currently running AT&T Fiber and DirectTV via a BGW210-700 Gateway.   I purchased an Orbi RBK43 Wifi System to extend range and increase my bandwidth (RBR40 Router and two RBS20 Satellites.
I set up the Orbi Router in AP mode and it is connected via Ethernet to the BGW210.   Since I cannot turn off the BGW210's Wifi due to the DirectTV and home phone line coming off the BGW210, is there a concern about having the two routers operating concurrently and in close proximity?
1.  Is there anything I can do to improve this configuration?
2.  Is there anything I can do to reduce the potential for radio interference or other issues?  I thought I had read something about dedicating channels between the two devices if I need both networks.
Thanks in advance for any suggestions.
  • FURRYe38's avatar
     Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Besure if your using wifi on the ISP modem to set channels as far away from what you set on the Orbi. ISP modem set channel 1, Orbi set channel 11.
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    • rrh770's avatar
      rrh770
      Thanks.  Will try the settings for the Radio's.
      >6,000 sq ft across three levels.   Internet comes in at the edge of Level 1.   I'm close to 30' straight up through two floors to one, and about 30-40 feet on Level 2.  Both registered and turn blue.   Would be nice if the indicator lights stayed on so you could always see the status.
