jwrich4's avatar
jwrich4
Orb Firmware Update
August 2018, received an email there was new firmware for my router. I installed it and bricked the router. It took 3 days (Netgear doesnt have overnight or one day service for it's non-business customers) to get a replacement router.Worked with TechSupport and got it talking to my satelitte and I asked if I should try and update the firmware again. The Tech almost came through the phone telling me "No, Dont do it!".
Now, I have another email telling me there is new firmware for my router. Pardon me if I'm a little gun shy, I dont want to go through another bricked router without having someone from TechSupport on the phone while doing the upgrade. But you cant just call and speak to someone, you have to write the Community. So, here I sit typing away. I want to ensure my network is secure but bricking a router is not the level of security I'm after, It cases lost wages. Any suggestions for a way forward?
  • CrimpOn's avatar
    CrimpOn
    It would help to know the model of Orbi and the current software level.  Unless the tech told you some "secret", the Orbi is going to update automatically without asking.  Mine has updated at least 3-4 times and the first I know about it is when I read people in the community complaining about what broke.  If updating this one is going to "brick it", I would want that to happen during the warranty period instead of one day after it expires.
      • CrimpOn's avatar
        CrimpOn
        Well, 2.2.1.210 is the latest software.  There is a beta version that some people are testing, but there has been NO announcement of an update.  Do you remember where that email came from?
  • CrimpOn's avatar
    CrimpOn
    I just read more carefully. August of 2018?  Email notice?  When does your warranty expire?
    • jwrich4's avatar
      jwrich4
      Warrenty expired a year prior. Because I was following NetGears suggestion and upgrading the firmware when it "bricked" they sent me another. I just spoke with Customer Service and explained my desire NOT to go through this again. They had nothing to except "it probably wont happen again." Comforting...
  • FURRYe38's avatar
    Any FW updates please review the NG download site for recent and most current versions of FW. It's recommended to manually download FW files and install them yourself instead of using the Auto Update in the routers UI. Known problems with using auto update. If you have used the autuo update and your system doesn't seem to work well, do a manual FW installation using downloaded files and then factory reset and setup from scratch, if this is needed.
    I too get emails from NG about FW updates. It's up to you to check on it and review the information. Check the NG support pages first before taking action.
