ChewBiscuit's avatar
ChewBiscuit
Orbi - do all models require an existing modem? Also, which one to get?
Before I buy, just wanted to check if there are any models of Orbi where the base can act as a modem, or do ALL of the different models require an existing modem? Also, what is the best model for g...
  • DarrenM's avatar
    Oct 23, 2017
    no orbi model has a modem built in so you will still need a modem.
    DarrenM
