jjakubow's avatar
jjakubow
Initiate
May 04, 2017
Orbi - OpenVPN
I read the instructions on how to install the VPN on my orbi , I read the prior post on setting up the VPN, and watched a video on how to do it on you tube.
I made a dynamic dyns account with no-ip.
 installed the latest stable version of tunnelblick
And yet I can;t seem to connect to my VPN. I belive the error below in the log is the issue.
2017-05-04 22:56:33 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
I'm not sure why the orbi does not seem to have  server certificate verification. Any thoughts on how to fix this? Thanks in advnce!
  • So I ended up paying for premium support. Turns out my problem was I didn't try testing it from another network. You can't connect to your own network with a VPN. No connection in my home. When I leave my network the VPN works flawlessly
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello jjakubow
    I would like to have our support team work with you on this can you send me a PM with your name, phone and email and I will have support contact you.
    DarrenM
