tln741
Nov 11, 2017Star
Orbi - why can't we change channels on satellites?
Wireless design best practice when installing multiple access points in an area is to have non-overlapping channels. So if you have 3 APs (RBR50, 2-RBS50) in an area, for 2.4 GHz, one AP would be cha...
Jun 18, 2018Guru - Experienced User
Also having wireless sources right above one another or in close range with the Orbi systems, will present problems. 30 feet in between to start is a good starting point for placement. Depending upon building materials as well.
The router alone and cover up to 30 feet by itself. the MESH system is still base on extender or repeater design so the satellies are still extenders. Even in wired back haul mode.
- tln741Jun 18, 2018Star
But directly below is where I want the hard wired ports.
Your solution is to rearrange my house so the Orbi works the way it was designed to work? It is a poor design to not allow channel assignments to address performance issues with co-channel interference AND I can't lower the power settings to try to reduce that co-channel interference either.
Make an advanced tab that allows the satellite channels and power levels to be adjusted.
- FURRYe38Jun 18, 2018Guru - Experienced User
Something you can post here to request about this and see if NG will review and respond:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Again, this maybe something thats not a feature with in the chipset of the actual wifi drivers for Orbi. Also this system is based on being fairly automatic for the average home user. Most users don't have this need to change any channels or power levels. Users mostly want to set the Orbi system up and have it work and thats it.
Good Luck.
- Netvllc2000Apr 25, 2019GuideMy experience make differ from others
- jimbojames79Jun 21, 2018Apprentice
Yes it would be really helpful to be able to adjust the powers levels individually.
My house is just too big to have a router on its own but when I add a satelitte and reduce the power, a chunk of the house is effectively wifi free because the devices get confused about whether to join the router or the satelitte. It's not too bad with fixed devices but for phones/tablets etc its a nighmare.
- FURRYe38Jun 21, 2018Guru - Experienced User
How big is your house? SqFt?
I used one router and one satellite in a 5000sq ft home. Router and satellite at opposite ends with 40 feet in between them.
