tln741
Nov 11, 2017Star
Orbi - why can't we change channels on satellites?
Wireless design best practice when installing multiple access points in an area is to have non-overlapping channels. So if you have 3 APs (RBR50, 2-RBS50) in an area, for 2.4 GHz, one AP would be cha...
Dec 29, 2018Guru - Experienced User
On Orbi systems, you can pick primart non overlapping channels.
Users need to remember that the reason why you can't pick channels on the satellites is that they are acting as REPEATERS/Extenders, thus when repeating, they have to be on the same channel as the source wifi signal channel. This doesn't work if the satellites was on a different channel from the source wireless. Repeatersand Extenders work on the same channel for this configuration.
molec
Jan 01, 2019Guide
This is circualar reasoning? WHY are the satellites acting as Repeaters/Extenders? It's by design choice of Netgear, I assume.
