Fowlkes523
Dec 14, 2019Aspirant
Orbi 11 Internet Connectivity Issue
Our Orbi 11 modem seems to lose connectivity to our Xfinity internet about once a day lately and I have to unplug the power and reset it. Is there a known problem with this modem or should I call Xfinity and check with them?
Do you have the cbk40 or which model do you have?
If you have another model, which modem is it?
If you do have a cbk40, can you take a screen snip of your modem connections page? It shows the status of your coax connectino signals.
- Fowlkes523Aspirant
Yes, it is a CBK40. I'll try the screen shot.
Thanks! that'll tell us a lot about your signal strength, errors, etc.
Any progess on this?
Fowlkes523 wrote:Our Orbi 11 modem seems to lose connectivity to our Xfinity internet about once a day lately and I have to unplug the power and reset it. Is there a known problem with this modem or should I call Xfinity and check with them?
