FredFlintston
Oct 12, 2019Aspirant
ORBI 2..4 gHz speeds
Hello
An ORBI RBR50 with very slow 2.4Ghz performance. I have a 50Mbs fibre service and wired connections and 5 ghz connections reach full speed but I have a tablet which is 2.4 only and it struggles to get up to 1Mbs. Often the speed test starts at 10Mbs but rapidly falls back to next to nothing.
The whole system seems a mess to be honest. The admin page shows the satelite but nothing connected to it, wireless devices show up as wired - trainwreck.
Some of the things i have tried:
Switching off all other wireless devices
Swapping wireless chanels
Switching off settings - daisy chain, mimo, fast roaming, beamforming
reset and reconnect satelite
Hardwire satelite backhaul
I have been away for much of the last 3 months and the issue has only been noticed in the last three weeks and my 90 days support expired 3 days ago while i was mucking around. Should I just return it?
Any ideas?
The satellite connection shows as "wired" and "good"?
Does this old tablet get faster speed when connected to a different WiFi system (elsewhere)?
Are there any other devices like phones, tablets, laptops, etc. which show "full speed" on 2.4G?
Are there any REALLY OLD WiFi devices connected to the Orbi?
(802.11 2.4G WiFi is "backward compatible" so that even the earliest WiFi device will still function. However, this can have the side-effect of slowing ALL 2.4G devices to the slowest speed.)
- FredFlintstonAspirant
Hello
Thanks for the reply. Here are the answers to the best of my knowledge:
The satellite connection shows as "wired" and "good"? Yes
Does this old tablet get faster speed when connected to a different WiFi system (elsewhere)? Yes - tethered to iphone
Are there any other devices like phones, tablets, laptops, etc. which show "full speed" on 2.4G? Most of the other stuff on 2.4 can't be tested (ipcameras and smart switches etc) My wife has a iphone 6 and she is having similar issues with often connection and full signal but no through put at all.
Are there any REALLY OLD WiFi devices connected to the Orbi? - the oldest thing is an ipad from about 2012. Everything else is less than 5 years old
Thanks for the answers. Hmmmm. iPhone 6 is "Dual Band", so it is not clear (yet) which band it is connecting on.
Do you use the Orbi "app" or the web interface?
Are you comfortable with telnet?
