jzryk8's avatar
jzryk8
Tutor
Nov 09, 2019
orbi 20 cannot connect Swann Camera
Newbie here. Installed my Obrbi RBR20 yesterday and all working ok apart from the fact I cannot seem to connect my Swann Indoor WiFi Camera (SWWHD-INTCAM).
It does not seem to be able to see the SSID of the Obrbi's. Anyone have a simple solution for a simple person ? ;-)
Regards
  • jzryk8's avatar
    jzryk8
    Nov 10, 2019
    I really wish to thank you all for the explicit instructions. Especially about simply turning off the SSID visibility on the band.
    All fixed now, so many many thanks to all.
    Regards
  • FURRYe38's avatar
    Are you using a custom SSID or default ORBI## SSID?
    Is the camera 2.4Ghz only supporting or does it support 5ghz by chance?
    • jzryk8's avatar
      jzryk8
      Tutor
      Hi thanks for the reply.
      Firmware is V2.3.1.58AU
      Using a custom SSID
      Unfortunately I think that is the problem on the Band, is a 2.4 Camera and my iPhone (which has the Camera Setup App) is defaulting to the 5.
      Regards
