Jds101's avatar
Jds101
Orbi 50 - flashing white / magenta satellites
I purchased the Orbi50 system from costco last year. It has worked great until a couple of days ago when I noticed the RBR flashing white and all the RBS magenta. I checked the modem and it indenticated nothing was connected. To troubleshoot I disconnected the orbi and plugged my laptop directly into the modem and my laptop worked fine. So clearly the issue is with Orbi, I tried calling netgear but they want $100 to trouble shoot?!?! What a scam... they should stand behind their product.
I tried reseting the RBR, holding in the button for 15 seconds but nothing happens, just keeps blinking white, no amber. The Orbi app is unable to connect as well.
Any idea what caused this and how to fix?
  • What Firmware version is currently loaded?
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    • Jds101's avatar
      Jds101
      MY COMMENTS PROVIDED IN CAPS BELOW. THANKS FOR THE GUIDANCE.
      What Firmware version is currently loaded? IDK, WOULD THIS BE DONE MANUALLY? I HAVEN'T HAD TO TOUCH THE SYSTEM SINCE I PURCHASED IT.
      What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? XFINITY / MOTOROLA MB7420 - NO ISSUES WITH THE MODEM, IT CONNECTS DIRECTLY WITH MY LAPTOP WITH NO ISSUES
      What is the size of your home? Sq Ft? TWO STORIES. 8,000 SF - WHY WOULD THAT BE A FACTOR CONSIDERING I HAVE HAD THE SAME SETUP FOR THE LAST YEAR.
      What is the distance between the router and satellite(s)? I HAVE 4 SATELLITES THAT ARE ROUGHLY 30 FEET APART. I HAVEN'T MOVED THEM SINCE FIRST INSTALLATION
      Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. I CAN'T CONNECT SO NO WAY TO CHANGE
      Any Wifi Neighbors near by? NO NEIGHBORS IN RANGE. If so, how many?
      https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
      I GUESS MY MAIN QUESTION IS, IF THE SYSTEM HAS BEEN UNTOUCHED HOW IS IT THAT IT ALL OF A SUDDEN COMPLETELY FAILS. SEEMS LIKE NETGEAR SHOULD SUPPORT ITS PRODUCTS. WHY WOULD I INVEST IN THEM AGAIN IF THE EXPECTATION IS ONE YEAR OF DURATION L.
      • FURRYe38's avatar
        Guru
        You'll need to log in to the RBRs web page and find the FW version that you have loaded.
        Possible your Orbi got a FW udpate and hasn't processed correctly.
        RBS need to be on same version of FW as well as RBR.
    Magenta usually means the device has lost connection
    https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
    • Jds101's avatar
      Jds101
      I tried factory reset, held a paper clip for over a minute and the RBR still flashes white, never amber.
      • vajim's avatar
        vajim
        Master
        Dead?
        how old?
  • After spending $89 and two hours on the phone with netgear they told me the RBR50 failed and I will need to purchase a new unit. Purchased the Orbi system just over a year ago and now they want me to purchase again? No thank you, I will go with a new company that stands behind their products and supports their customer. What a joke, how long until they take this post down!?!
    • vajim's avatar
      vajim
      Master
      I'm sorry to hear that
      wishing you all the best.
