ginunicyb
May 31, 2020Aspirant
Orbi 5Ghz Network
Hello,
It seems my Orbi's 5Ghz network stopped working. It doesn't show 5G channel in the Control panel dashboard. Also I can't see Orbi 5g in the WiFi analyser. The signal is set to 100% and channel is set in the settings.
Some additional screenshots here
Good to hear. Please mark your thread as solved so others will know.
Be sure to make a backup configuration to file for save keeping. Helps save time if a reset is needed again.
Enjoy. :smileywink:
ginunicyb wrote:
Full reset helped.
What is the Mfr and model# of the ISP modem the NG router is connected too?Has a factory reset and setup from scratch been performed since last FW update?
- ginunicybAspirant
What Firmware version is currently loaded? Router Firmware Version V2.5.1.8
What is the Mfr and model# of the ISP modem the NG router is connected too? Huawei HG659 VDSL modemHas a factory reset and setup from scratch been performed since last FW update? Nope, was hoping to omit doing reset.
Your Modem already has built in router and wifi. IS the modem fully bridged and wifi disabled? This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModeAfter making sure of the ISP Modem configuration, I would do a reset on the RBR and set it up from scratch. You can turn OFF the RBS while you do this, just set the same SSID name and PW and later on turn on the RBS and it should reconnect.
ginunicyb wrote:It seems my Orbi's 5Ghz network stopped working. It doesn't show 5G channel in the Control panel dashboard. Also I can't see Orbi 5g in the WiFi analyser. The signal is set to 100% and channel is set in the settings.
I agree with FURRYe38 that this is "damn odd." You might try changing the 5G channel from 36 to 48, "Apply", and after the Orbi comes back up perform a "regular reset". (Not a "Factory Reset". Just press the reset key (inside the tiny hole) for one second and let go.)
The business with Double NAT is correct, but seems irrelevant to the problem at hand. Orbi should broadcast both 2.4G and 5G channels even when not connected to a modem at all.
