jt_manhattan
Feb 09, 2017Aspirant
Orbi AC Adapter Replacement
I purchased an Orbi system on Amazon. Everything seems to work fine except that one of the AC Adapters is broken. When I switch the adapters the router and satellite work fine. I can only assuem t...
- Feb 10, 2017
Should be under warranty, no? Contact Netgear support.
djc6
Feb 10, 2017Luminary
- jt_manhattanFeb 10, 2017Aspirant
Thank you. That was the fastest solution.
