stelbry's avatar
stelbry
Orbi AC2200 RBK30 with no Modem
I purchased a single orbi with satellite today with hopes of having the same WiFi signal downstairs that I have upstairs where my old router is currently. The problem I’ve ran into is that I’m assuming I’m going to also need to purchase a modem. I’ve only ever had a router which is the linksys e1200. I don’t have cable. Stream Netflix and Hulu. Play Xbox and use my laptop for mostly school work. So, I guess my first question would be, do I have to have a modem to use the orbi or is there another way around it? Also, is there maybe a cheaper solution to my problem. The orbi isn’t cheap and if I’m going to need to also purchase a modem I’m not sure the price is worth fixing this issue at this point. Any ideas?
  • FURRYe38's avatar
    How do you get internet services with your old router?
    Who is your ISP?
    • stelbry's avatar
      stelbry
      My internet provider is North State Communications.
      • FURRYe38's avatar
        Is there a modem or just a wall outlet with a lan cable for internet access?
