Stoic-pillar's avatar
Stoic-pillar
Orbi AC3000 Satellite Unable to Connect via Ethernet Backhaul
Orbi AC300 v2.7.4.24
RBR50 - base
RBS50 - satellite
Hello! I’m confused as to how to setup my base and satellite for Ethernet backhaul. Both are connected to an AT&T modem with WiFi switched off and IP Passthrough enabled. Both Orbis have assigned IPs.
According to Netgear docs, this should work with a switch. (3rd diagram)
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
While the base is successfully online I have tried just plugging in my satellite. Then I’ve tried rebooting both the modem, base, and satellite. I’ve tried re-syncing the satellite.
If I plug my Ethernet from my modem to RBR50’s LAN port the whole system goes offline.
On my modem I’ve
  • CrimpOn's avatar
    CrimpOn
    Dec 02, 2024
    Stoic-pillar wrote:
    I was hoping to link both the RBR and RBS directly to the modem, in a similar fashion to the documentation.
    Alas, you are not the first person to reach the wrong conclusion from this diagram.  What the drawing does not show is the link between the Orbi system and the Internet.  Installation instructions describe connecting the WAN port to the Internet Service Provider.  Where should it be?
    If only the person creating these drawings had shown the router WAN port connection, people would not attempt a connection that simply does not work.
    One suggestion is to try this:
    • Move the RBR50 router to the modem location and connect the WAN port to it.
    • Place the satellite in one of the other locations and connect it to one of the router LAN ports.
    • Place the switch in the other location and connect it to a different router LAN port.
    There are still two WiFi devices. There are still Ethernet ports in three rooms.
  • FURRYe38's avatar
    Did you plug in the RBS to the back of the RBR and see if they connect. Need to give about 3-5 minutes and the top ring should turn blue.
    First make sure the RBS wirelessly connect to the RBR. Once thats done, then ethernet connect them behind the RBR.
    Brand and model# of the switch?
    Be sure the switch is connected BEHIND the RBR, then the RBS to the switch.
    • Stoic-pillar's avatar
      Stoic-pillar
      Thanks for the quick reply!
      The modem is AT&T/nokia BGW320-505.
      The modem is in the “Library.” The RBR in the family room and the RBS in the “office.”
      The modem feeds into three Ethernet drops, the two relevant CAT6 runs lead to the library and office
      Stoic-pillar
      I was hoping to link both the RBR and RBS directly to the modem, in a similar fashion to the documentation. Will this not work? Do I need to acquire an unmanaged switch to do this?
      I don’t have a good way of running Ethernet from my RBS/satellite to my RBR/base.
      • CrimpOn's avatar
        CrimpOn
  • CrimpOn's avatar
    CrimpOn
    AS FURRYe38 pointed out, this is the problem.  Connect the RBR50 ('router') WAN port to the AT&T device and the RBS50 ('satellite') to one of the router LAN ports.  Yes, a non-managed switch can be between the router and satellite. The key is that satellites must appear on a LAN port.
