jules2323
May 08, 2018Aspirant
Orbi and BT Home Hub 4
Hi,
My setup consists of a BT Openreach DSL box which in turn is connected via ethernet to my BT Home Hub 4. I have disabled wifi on the home hub and plugged my Orbi in .. in router mode. Everything seems to work but as expected... it has created a second 10.x subnet for the Orbi network.
My question is, should I switch to access mode on the Orbi or better still can I just remove the BT Home Hub and plug the Orbi router into the Openreach DSL box to simplify things and have everything back on the 192.x subnet?
If you can bridge the modem/hub so that the Orbi router gets a public IP address, this would be preferred. If not, then if the modem/hub has a DMZ feature, you can use this feature on the modem for the Orbi routers IP address it gets from the modem/hub and use the Orbi router in router mode instead of AP mode. This helps with double NAT conditions.
- jules2323Aspirant
Thanks for the reply. Unfortunatly internet tells me BT Home Hub 4 does not support bridge mode. DMZ option looks limited.
So I guess, access point mode or I by something like a Netgear DM200 to replace the home hub 4?
Or live with the seperate subnet
Give the DMZ a try...should work for Orbi in router mode.
I would check with your ISP first to see what they support or BYOM.
Some say that the DM200 is not a good modem.
