virghilts
Oct 28, 2016Aspirant
Orbi and Cable Modem/Wifi Router
I'm interested in purchasing the Orbi System but have a couple of questions. My ISP provides a Modem/Wifi Router. I use it as a single gateway to hardwire devices and use the two bands, 5G and 2G for wireless signals. When using the Orbi system should the Wifi on the ISP Modem be disabled? If not disabled, will broadcasting the networks degrade signal for the Orbi. If I have multiple devices hardwired to the Modem is it best to hardwire into the Orbi vs the Modem/Wifi Router? Sorry a newbie a this so trying to learn which may be basics.
Thanks
virghilts wrote:. When using the Orbi system should the Wifi on the ISP Modem be disabled
th simple answer is yes , that is if you intend to use the modem as the router as well and set the orbi system to AP mode which in most cases is the best course of action atm
if you ran the routers wifi as well it may confuse the way the obri works as far as band steering and ap steering
pete
- virghiltsAspirant
Thanks PeteyTesting, so i understand, best practice sounds liek using the modem, strictly as the modem, connect the Orbi as my Wi-fi and hardwired router. If I use the modem as teh router for hardwired devices the Orbi needs to be set in Access Point mode. Is there any signal loss with AP mode?
hi
no signal loss in AP mode
you may not be able to bridge the modem if you have voip or iptv etc running from the modem router
