Jazzper2
Jun 16, 2020Guide
Orbi and EX8000
I recently replaced my R6400 and EX8000 extender with an Orbi RBK40 and one satellite. However, I need an ethernet port in the room where the etender was previously located so I tried to get the EX8000 to connect to the Orbi. I go thru its configuration and it sees the SSID and accepts the passkey but then it say it's not connected. I even tried setting it up right next to the Orbi and got the same results. I don't understand why the EX8000 cannot connect to the Orbi via WiFi -- are they not compatible? Running an ethernet cable out to the other room is not an option. If for some reason the EX8000 and Orbi are not compatible (why?), are there other options or should I just return the Orbi?
Did you try the WPS setup?
https://www.downloads.netgear.com/files/GDC/EX8000/EX8000_QSG_EN.pdf
- Jazzper2Guide
Good idea....I'm a "put the info in manually" kind of guy but it's worth a shot-:)
- Jazzper2Guide
Just tried your WPS idea -- no luck, even from about 12" away from Orbi. I then thought maybe it does not like using the same SSID so I tried it with "EXT" on the end of the names but same result. I go to the EX8000 admin screen via an ethernet connection, it lools like it sees the Orbi WiFi SSID, I put in the passkey and it looks like it takes it, but after I hit "Continue" it says it cannot connect.
When I use a different SSID for the extender, I can connect to it via Wifi but can't go any further. A traceroute dies there and when I connect to the Orbi, it does not see the EX8000 in its list of connected devices.
I'm out of ideas!
There have been incompatibilities with EX and Orbi in the past.
Has the FW on the EX8000 been updated?
Jazzper2 wrote:I recently replaced my R6400 and EX8000 extender with an Orbi RBK40 and one satellite. However, I need an ethernet port in the room where the etender was previously located so I tried to get the EX8000 to connect to the Orbi. I go thru its configuration and it sees the SSID and accepts the passkey but then it say it's not connected. I even tried setting it up right next to the Orbi and got the same results. I don't understand why the EX8000 cannot connect to the Orbi via WiFi -- are they not compatible? Running an ethernet cable out to the other room is not an option. If for some reason the EX8000 and Orbi are not compatible (why?), are there other options or should I just return the Orbi?
I think your EX8000 should work with your new Orbi, or any other wifi router, so it is confusing that you're unable to connect it. Unfortunately the troubleshooting recommendations haven't worked for you so far.
As a workaround, since you just need an ethernet port access, how about using your old R6400 just as a wireless bridge to your Orbi network? It can provide ethernet port access as you were trying to setup your EX8000. Example bridge setup instructions are here (this is for a different Netgear model but the instructions should be similar): https://kb.netgear.com/24105/What-is-bridge-mode-and-how-do-I-set-it-up-on-my-Nighthawk-router
- JazzperAspirant
Thx. This does look like the best alternative - pending an answer from NG tech support. I was hoping to be able to give my router to a friend but I'm going to give this a shot.
Hopefully there's nothing in these Orbi's that would prohibit bridging to them-:)
Again, thanks all for your suggestions.
I'm still very confused. Using the WPS buttons to connect a device to WiFi involves NO "entering passkeys". That's the whole point of having a button. (which some people describe as a horrible security breach, but that's a different topic.)
There is no setup. Power it up. Press the WPS button. Press the other WPS button. Lights come on. New WiFi SSID's appear with the same password as the primary WiFi router. Once it is working, then the user can access the management interface and change settings.
- BetomanAspirant
I have a EX8000 extender because I decide to upgrade to and Orbi Wifi 6 system. I sold everything else except the extender so I decided to do some research just to see if it can connect to the Orbi system. After researching I decided to do a test. Just now I was able to sync the satellite with the EX8000 and it works as expected. The only issue is that I see the satellite and the extender it came with but the EX8000 comes up as an extra device. My only question is would that affect the Orbi router? Also, it appears that the EX8000 only functions at 2.4 GHz, I'm assuming because that's the only option appearing when going through the Orbi app.
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axDoesn't effect the RBR. Just works as a extender only. Check the EX web page for status and connection.
Thank you.
Betoman wrote:I have a EX8000 extender because I decide to upgrade to and Orbi Wifi 6 system. I sold everything else except the extender so I decided to do some research just to see if it can connect to the Orbi system. After researching I decided to do a test. Just now I was able to sync the satellite with the EX8000 and it works as expected. The only issue is that I see the satellite and the extender it came with but the EX8000 comes up as an extra device. My only question is would that affect the Orbi router? Also, it appears that the EX8000 only functions at 2.4 GHz, I'm assuming because that's the only option appearing when going through the Orbi app.
