Zoethedog's avatar
Feb 11, 2018
ORBI and horible streaming media performance.
Hi,
To Orbi support, do you ever intend on fixing these units so that streaming media can actually work longer than 4 minutes, or I just have to chalk this up as a terrible purchase wasting about 500 dollars and purchase another brand? I just want to know so I can plan accordingly. Thank you in advance for an honest answer.
  • I can stream both plex and Sling tv all day, both wired and wireless no problem.  Perhaps the issue isn't entirely the router.
    • Thanks for the reply.  It is a problem with this router, and yes some devices are fine such as roku. Other devices get kicked on and off constantly. My past router did not do this, but had a smaller range. This problem has been report ad nausium here. I've had contact with support about Amazon echo getting dropped repeatedly, and that seems to have been made better with the last update and a few suggested advanced setting changes, which are not documented anywhere so I think we can assume here a work around. I am not a tech noob, and I know how to drill down through variables to pinpoint issues. So, when several devices exhibit the same behavior we can probably rule out individual devices. When the internet speed and reliability test with high results, we can rule that out. When a device that is known to be problematic exhibits the same problems that others keep reporting without resolution I think we can safely assume from where that problem originates. All I want to know, and I'm sure others do too, is if this expensive p.o.s. is going to be fixed or do I junk this system and resolve to not purchase from this unreliable brand again. Cheers.
      • JoeCymru's avatar
        JoeCymru
        Virtuoso
         Not wanting to teach my grandmother how to suck eggs, just curioious. Is fast roaming enabled or disabled? How is the backhaul doing? How many satellites do you have? Are you in a star or daisy chain mode? What is the signal strength 15' away from router and each satellite? Can you see it drop and reappear? It seemed to me that the .18 changes affected some people dofferently. Did you try to go back to old firmware?
  • I am streaming what 4K content there is without any hitch or bufferring. The local host on my TV is connected solid at 5GHz. Running ookla speedtest on Google on my TV shows I am getting full contracted download from my ISP. Been in operation since mid November, gone through initial firmware update and .18 update, with only one minor issue (backhaul topography needed switching to daisy chain off).
    Without more details on your situation, not sure anyone here can help ... if that is your intention.
    • Zoethedog's avatar
      Zoethedog
      Guide
      Thank you for the reply. Specifically,  4 roku units preform just fine since December. 4 echo/dot units exhibit lost connections. Chromecast is now very unreliable. IPhones/androids also drop but not so frequently as other devices. Nothing is far away for an antenna. A Yamaha a/v reciever drops contantly now when streaming.  Nest and my frontpoint alarm seem to be ok, but they are not real-time apps. Thank you.
      • tsig's avatar
        tsig
        Luminary
        Lets see if I can remember all my devices.
        Roku's, Zmodo video doorbell, (2) Sharx camera's, Iphones, Ipad, Android tablet, Roku Tv, HP wireless printer, Schlage front door lock, Onkyo receiver, PC
        None have had issues.
