Kaput5
Feb 03, 2018Star
Orbi and Ring products issues
I recently switched from one router + repeater to the Orbi system. No installation problem. When I first connected my Ring Doorbell and 2 Ring Spotlight cameras, no connection issues. One camera ...
Feb 24, 2018Guru - Experienced User
I haven't had any issues with 3 cameras, 2 NEST controllers and the rest of my network. I disabled the following on the Orbi router:
Implicit BEAMFORMING - Boosts WiFi speed, reliablity, & range for all mobile devices
MU-MIMO
1 Satellite attached using both wifi and LAN for back haul.
rawbuttwrote:
So is it pretty much a general consensus with this issue that unplugging all Orbi satellites and just running the router is the same as testing with a standalone (non mesh) router or does this issue still sometimes persist even with only the one Orbi router node running?
rawbutt
Feb 25, 2018Star
I apologize if this has already been answered, but does anyone have any explanation why my issues seem to be with live view and only when there is active motion? I am down to only the orbi router plugged in, no satellites the recommended options disabled and still having issues with Live View when there is motion but almost never when there is no motion.
- FURRYe38Feb 25, 2018Guru - Experienced User
Live View?
rawbuttwrote:
I apologize if this has already been answered, but does anyone have any explanation why my issues seem to be with live view and only when there is active motion? I am down to only the orbi router plugged in, no satellites the recommended options disabled and still having issues with Live View when there is motion but almost never when there is no motion. - RoamaboutFeb 25, 2018Luminary
rawbuttwrote:
I apologize if this has already been answered, but does anyone have any explanation why my issues seem to be with live view and only when there is active motion? I am down to only the orbi router plugged in, no satellites the recommended options disabled and still having issues with Live View when there is motion but almost never when there is no motion.My Ring doorbell pro has always behaved like that, both pre and post Orbi. I always figured it was by design, ie the Ring doorbell is busy capturing video and uploading it to the Ring cloud and it cant do that and support a live view connection at the same time. I have no facts to corroborate that, it was just my rationalization.
- rawbuttFeb 25, 2018StarYes... My issues with accessing Live View seem to be only when there is motion. I tested it all morning with no issues one morning recently. Then when workers showed up in the backyard, I had issues from that point forward with Live View.
- Kaput5Feb 25, 2018Star
I think it is a correct assumption. I have a similar behavior with my cameras.
The logic would be that as the device is busy capturing the 30 seconds of video started by the motion, it will not go Live. In fact if you want to go Live when a motion has just been detected, click on your notification and it will take you to the Live feed.
- rawbuttFeb 25, 2018StarKap... I agree. I have even noticed that I have better luck if I click on the notification then I do the live feed button. But is that the way it is supposed to work? Shouldn't I be able to do a live feed at the same time it's capturing motion?
- rmadilaoFeb 25, 2018GuideYou should be able to do both live view and motion capture recording. Its works for me but performance varies on camera location. The devices closer to the router have better live view performance while capturing motion. However, i have also experienced cameras getting overloaded if more than one is triggered. The live view signal is a raw feed while the motion capture is compressed on the Ring servers.
- rawbuttFeb 25, 2018StarWhat exactly is the bottleneck when doing both? I have a 600/600 fiber connection so hard to imagine it's bandwidth.
- rmadilaoFeb 25, 2018GuideI have yet to figure out what the bottleneck is. I know your camera would still have to upload its feed to Ring and then you are downloading it back to view either Live or a recorded video. I wonder if the bottleneck is at Ring’s servers as it gets more and more popular with more people using them. If that were the case, your own internet bandwidth would be irrelevant. The key issue is, is the problem at your house or upstream with Rings server? Having said that, all 6 of my cams work great now. Good sound through mic and live view working with either self initiating or motion triggered.
- rawbuttFeb 26, 2018Star
This morning, I unplugged the Orbi altogether went back to the Netgear R6300 that came from my ISP. It's just a basic 2.4/5Ghz non-mesh router. I checked all 4 Ring cameras afterwards and verified that they all had a "Good" signal strenth rating in the Ring app. The all had 52 or lower RSSI. I still had issues connecting to Live View once it detected motion...things like following a family member from camera to camera as they walked around the house. I'm considering abandoning Ring altogther and giving Nest a try. I mean, if I can't get into Live View consistently when there is motion (i.e. an intruder), what good are the cams to me?
- rmadilaoFeb 26, 2018Guide
rawbutt That sucks. I got all of mine to work now with Live View with either self-initiating or motion triggered. And its works quite fast too. Have you tried contacting Ring and tell them you are using a regular single router and Live View still does not come up? I'm actually having my Live View triggered by motion on my desktop machine right now as I'm typing this and it's working fantasic. I do know that they have had to tweak and adjust some settings on their server side for my setup. Perhaps, they have to do the same thing for you?
Well I think I may have figured out what my issue was with not being able to do Live View when there is motion. I guess it was mainly a procedural thing on my end that just never dawned on me. To date, I have always viewed the motion notification that comes down from the top of the Ring app as just informational in nature. I would see it and then click the usual blue Live View button to try to go to whatever camera I just got notified about. According to the Ring tech support rep I spoke with tonight, I am told that will not work and that I must be pressing the actual notification instead of the Live View button. I apparently cannot give me the raw Live View feed while uploading the 30 second montion-triggered event to the Ring system. So now I'm starting to wonder if this was really what I was experiencing with the Orbi when I originally assumed it was a mesh wifi issue. I am going to go back to my Orbi tonight and troubleshoot it further now.
rawbutt . Interesting. TBH, I think it should work either way. The thing is though, if you did have a motion triggered event happening, and you load the Ring App, it should automatically go to the Live View by itself. It won't even give you a chance to touch anything in the app when a motion triggered event happens and you load the Ring App, UNLESS, you have motion alerts disabled for that camera. Then it won't auto load the Live View. Haha, confused yet?
- rawbuttFeb 27, 2018Star
@rmadilao Actaully, the Ring app used to behave exactly like you described. When motion was detected, it would automatically send you into Live View mode for the camera with motion, but after an update a while back, it now just gives you a notification at the top about the motion.
- wildsubnetFeb 27, 2018Apprentice
This isn’t a Ring issue, it’s something between Ring and Netgear. So maybe Nest cameras will work better (certainly my Nest thermostat stays connected to the Orbi). If you google around this issue pops up a lot in regards to Netgear routers (not just Orbi).
Just to update, I haven’t had a single issue with Live View since taking the Orbi out of the equation. But again, that doesn’t mean the problem is necessarily with Netgear. It just means whatever is happening Netgear isn’t handling very well. The ring device could be doing something completely out of specification. It also means it will be very difficult for an end user to troubleshoot. Someone at Netgear and/or Ring needs to put these two devices in lab and do some real testing to figure out what the problem really is.
- rmadilaoFeb 27, 2018Guide
rawbutt Both my desktop app and mobile app automatically go into Live View video when motion is triggered while the app is running in the foreground and I'm on the latest versions. I did experience what you described too a couple weeks ago where it wasn't automatically going into Live View with motion. I deleted the app and re-installed it. The update may have messed up something, but it works like before now.
I used to have all sorts of problems with Live View. Now I simplified my setup to only 2 nodes with the Orbi Pro system. (I attempted 3 and 4 nodes and there were constant issues, not just with Ring but with mobile phones, laptops, etc. Too much interference). Recently, replaced 3 out of 6 of my Ring cams under warranty. Now everything is working great. I've even been able to turn Implicit Beamforming and MU-MIMO back ON and it's all still working.
- rawbuttFeb 28, 2018Star
Has anyone compared the difference between the Ring app on an iPhone and an Android phone? Wow. I just tried this morning and could not believe the difference. Everything is just much faster and smoother on iOS it seems. I always thought the 7 second delay I had when clicking on Motion Settings | Motion Zones was normal but with an iPhone, it's instant. Even Live View seems to perform better/faster in iOS. It feels like iOS might have been the native OS for their code and they just ported over to Android. I even found an option in the Ring app that only shows up on iOS and isn't there on an Android. If you go into any of your cams' pages in the app and click on the gear icon at the top right, there's an toggle option called "Alerts Open Fullscreen Video". This option is only in iOS apparently and explains my confusion about why my Android does not open Live View automatically when motion is detected like it used to...now just get the notification that I have to click on, but others were saying they were getting the automatic full screen. I bet they were using an iPhone.
Hopefully with Amazon's acqusition of Ring announced yesterday, we'll see some nice new features and improvements!
- rmadilaoFeb 28, 2018Guide
The "Alerts Open Fullscreen Video" button is relatively new with the recent APP update to support the iPhone X screen size (with the notch). It wasn't always there. Also, I have that setting disabled for all my cameras and I still have the Live View video automatically come up when it triggers motion as long as I'm in the RING app. If I'm not in the RING app, then it just does a notification. That new toggle setting may get annoying if it always opens fullscreen video regardless if you are in the RING app or not.
I am told today by Ring tech support that the Ring Alarm will be available "VERY VERY" soon and that we will get the Ring app major update at that time with multi-camera views, etc. I'm hoping that maybe that will be basically a re-write of the code and that there won't be such a noticeable different between the performance of the iOS and Android versions.
Yeah, they're busy putting on the Amazon label on all the Ring products. :))
You know, it could get worst instead of better as more features are added, if they didn't do a complete code re-write (which they almost never do). :P . Hope for the best...
- rawbuttFeb 28, 2018StarJust seems like Amazon likes to be on top at whatever they do and wouldn't want a black eye of any sort with this acquisition. And with all the Amazon money they have to throw at it, hoping it's impressive. Hoping for the best here as well!
