Kaput5
Feb 03, 2018Star
Orbi and Ring products issues
I recently switched from one router + repeater to the Orbi system. No installation problem. When I first connected my Ring Doorbell and 2 Ring Spotlight cameras, no connection issues. One camera ...
cyberprashant
Mar 27, 2018Luminary
I was having problems with live video with ring stuttering or not loading. CHeck your bufferbloat rating at dslreports speedtest - I was getting a "C" rating. I added QOS ON setting on my upstream router of the ORBI (but you can do same with Orbi) and the video quality is much more stable and clearer. Might help someone. My bufferbloat is now a "A" - Charter Cable 300 down and 20 up.
- rawbuttMar 27, 2018Star
Where can I find the setting/config on Orbi for the QoS that you mentioned for addressing bufferbloat? All I see in the QoS section is a Speetest. I am running v 2.1.2.18 of the firmware.
Thanks!
