Kaput5
Feb 03, 2018Star
Orbi and Ring products issues
I recently switched from one router + repeater to the Orbi system. No installation problem. When I first connected my Ring Doorbell and 2 Ring Spotlight cameras, no connection issues. One camera ...
Vern75
Aug 19, 2018Aspirant
For those now not able to connect to ring doorbell to your Orbi— what worked for me was to purchase the “ring chime pro” it’s a WiFi extender ($50). It sucks I know but that’s the only way. The ring chime pro connected to Orbi and the doorbell connected to the chime pro.
jmc262
Aug 19, 2018Guide
Did anyone try turning off NAT filtering? Once I turned that off I’ve had no connection or notification issues.
- FURRYe38Aug 20, 2018Guru - Experienced User
How many of these devices do you have online at one time? Possible port routing issue. See this with two or more game consoles online at the same time needing same ports, NAT Filter set to Open helps for these configurations...
