Kaput5
Feb 03, 2018Star
Orbi and Ring products issues
I recently switched from one router + repeater to the Orbi system. No installation problem. When I first connected my Ring Doorbell and 2 Ring Spotlight cameras, no connection issues. One camera ...
jmc262
Aug 19, 2018Guide
Did anyone try turning off NAT filtering? Once I turned that off I’ve had no connection or notification issues.
Aug 20, 2018Guru - Experienced User
How many of these devices do you have online at one time? Possible port routing issue. See this with two or more game consoles online at the same time needing same ports, NAT Filter set to Open helps for these configurations...
