Kaput5
Feb 03, 2018Star
Orbi and Ring products issues
I recently switched from one router + repeater to the Orbi system. No installation problem. When I first connected my Ring Doorbell and 2 Ring Spotlight cameras, no connection issues. One camera ...
wildsubnet
Feb 16, 2019Apprentice
Nothing to do with double NAT. The ring devices simply disconnect from the netgears after awhile. I had put mine on an old AP plugged into my Orbi sat to get it to stay online. Based the research I did at the time this is pretty common issue with Ring and Netgear routers.
rmadilao
Feb 16, 2019Guide
Yup. It happens on the battery based Ring devices with Orbi. I have 6 Ring cams. All wired ones connect fine to Orbi. The battery ones need a Ring Chime Pro in between to maintain connectivity.
