Kaput5
Feb 03, 2018Star
Orbi and Ring products issues
I recently switched from one router + repeater to the Orbi system. No installation problem. When I first connected my Ring Doorbell and 2 Ring Spotlight cameras, no connection issues. One camera ...
jrmarinaro
Jul 17, 2019Tutor
I,m having the same issue, neither Netgear or Ring seem to eager to fix the issue, I added another Ring Chime Pro which fixed the issue for a short time them I had issues with my doorbell and courtyard cam trying to connect to the furthiest Ring Chime Pro which resulkted in a weak wi-fi signal, no help from text support on either side!
Den34
Jul 18, 2019Guide
Message #201 by FURREYe38 (right above your post) contains a link to the settings that work best for Ring Doorbells and the Orbi Mesh networks. What I've found is that even after getting everything working perfectly for days, my Ring Doorbell2 will occasionally go back to giving me fits. I continue to experiment with placement of the satellites. Things seem to work well for a little bit, and then it's back to the same old thing. Personally, I'm not liking the ring doorbell products at this point.
