LewisKennebrew's avatar
Dec 27, 2016
Orbi and UVerse Wireless Receivers
I've installed the Orbi AC3000 Tri-Band WiFi System with an AT&T Uverse system.  I replaced the AT&T Wireless Access Point with the Orbi main Router and configured it for AP mode.  After successfully...
  • RonV42's avatar
    RonV42
    Jan 04, 2017
    Sorry to say but there is no way of replaceing the NVG599 with the Orbi.  NVG599 is needed to inteface with Uverse, Uverse uses a signaling standard of VDSL,  bonding two pairs to give the bandwith along with HPNA for coax Uverse and voice services.  It's switch is also what is considered a IGMP switch which means that when two or more Uverse recievers are watching the same show there is only one stream coming from AT&T and the switch handles the multicasting.  That is why there are issues with Uverse recievers attached behind a second router.
    Bsed on what you are telling me is that all 4 of the LAN ports of the NVG599 have Uverse receivers or the WAP for the wireless reciver attached.  The only solution is to get a decent switch.  AT&T was installing a Netgear Fast Ethernet switch with 5 ports for household with more that 4 receivers when they did my install.  Some techs now install the GS205.  Here is a link on Amazon and the price is very low:
    Netgear GS205
    So what you should do for best performance is do the following on the NVG599:
    LAN Port 1:  Uverse Receiver
    LAN Port 2:  Uverse Receiver
    LAN Port 3: Orbi Router
    LAN Port 4: GS250 Switch
    Then plug your other Uverse receiver and WAP into the GS205 switch:
    Port 1: to NVG599 Port 4
    Port 2:  Uverse Reciver
    Port 3: Uverse Wap
