LewisKennebrew
Dec 27, 2016Aspirant
Orbi and UVerse Wireless Receivers
I've installed the Orbi AC3000 Tri-Band WiFi System with an AT&T Uverse system. I replaced the AT&T Wireless Access Point with the Orbi main Router and configured it for AP mode. After successfully...
- Jan 04, 2017
Sorry to say but there is no way of replaceing the NVG599 with the Orbi. NVG599 is needed to inteface with Uverse, Uverse uses a signaling standard of VDSL, bonding two pairs to give the bandwith along with HPNA for coax Uverse and voice services. It's switch is also what is considered a IGMP switch which means that when two or more Uverse recievers are watching the same show there is only one stream coming from AT&T and the switch handles the multicasting. That is why there are issues with Uverse recievers attached behind a second router.
Bsed on what you are telling me is that all 4 of the LAN ports of the NVG599 have Uverse receivers or the WAP for the wireless reciver attached. The only solution is to get a decent switch. AT&T was installing a Netgear Fast Ethernet switch with 5 ports for household with more that 4 receivers when they did my install. Some techs now install the GS205. Here is a link on Amazon and the price is very low:
So what you should do for best performance is do the following on the NVG599:
LAN Port 1: Uverse Receiver
LAN Port 2: Uverse Receiver
LAN Port 3: Orbi Router
LAN Port 4: GS250 Switch
Then plug your other Uverse receiver and WAP into the GS205 switch:
Port 1: to NVG599 Port 4
Port 2: Uverse Reciver
Port 3: Uverse Wap
RonV42
Dec 27, 2016Luminary
The RG is AT&T's Uverse Modem, called a Residental Gateway. The recomendation is to have the Orbi be the primary router in your home and setting the RG as IP passthough to your Orbi. This would allow your Orbi to be the router and firewall to all your private devices and uverse devices would directly connect to the RG either wired or wireless.
What model of the Uverse residental gateway do you have?
LewisKennebrew
The Residential Gateway model is a Motorola NVG599. A few questions if you don't mind me asking.
- What are the instructions for replacing the RG with the Orbi as the Router?
- Will I then need to reconnect the U-Verse provided Wireless Access Point?
Thanks for your help.
