Trusted_Whitey's avatar
Jul 20, 2018
Orbi App in Access Point Mode
Is it possible to use the Orbi app when the router is just in access point mode and using a non-netgear router? I would just like to be access the Wi-Fi settings
  • FURRYe38's avatar
    Yes and the app only supports Orbi systems. For non orbi NG routers, you have to use Genie for those models.
    • Trusted_Whitey's avatar
      Trusted_Whitey
      Thanks for the reply.
      Just to be clear and I wouldn't be using any type of netgear router (a draytek in fact) just an Orbi router in access point mode with two other satellites.
      I just want to use the Orbi app to access the Wi-Fi settings
      • FURRYe38's avatar
        Should work fine for AP mode.
