chuahyenhua
May 04, 2017Apprentice
Orbi automatic restart on new firmware! 1.9.1.12
This morning, the ORB updated its firmware automatically and restarted again. I thought the system would usually prompt the user for update instead of auto update. Is there a feature not to auto u...
fbraz50
May 05, 2017Apprentice
My issue is outlined in that post but long story short the new firmware caused me packet loss. I would never lose connection but I would get spurts where no traffic was being passed to the Internet is in essence what I saw on this new version. Not totally sure that's the same issue but it might be related.
This router combo is awesome and incredibly fast, when it works. I was all good up until this last firmware release which you can't block. What I did was block it at my router. I was able to do this because I use the Orbi's as just access points.
chuahyenhua
well, i hope they can come out with a feature to allow user to upgrade or not.
Suddenly this morning, all my apps could not work and i was wondering why.
then i saw all my CCTV network camera went down and up and concluded its the router since it is also a DHCP server.
- DarrenMMay 23, 2017Sr. NETGEAR Moderator
Hello Chuahyenhua
Did you ever get your devices working again?
DarrenM
- chuahyenhuaMay 23, 2017Apprentice
Hi
Yup. the devices are working but the main point is that the Orbi should not automatically download the latest firmware without user intervention. The user should have the perogative to decide when to update.
regards
chris
- MarkC1024May 24, 2017Luminary
This appears to be corrected with the most recent update. Mine did not update until I logged into the router and told them to.
