chuahyenhua
May 04, 2017Apprentice
Orbi automatic restart on new firmware! 1.9.1.12
This morning, the ORB updated its firmware automatically and restarted again. I thought the system would usually prompt the user for update instead of auto update. Is there a feature not to auto u...
chuahyenhua
May 05, 2017Apprentice
well, i hope they can come out with a feature to allow user to upgrade or not.
Suddenly this morning, all my apps could not work and i was wondering why.
then i saw all my CCTV network camera went down and up and concluded its the router since it is also a DHCP server.
DarrenM
May 23, 2017Sr. NETGEAR Moderator
Hello Chuahyenhua
Did you ever get your devices working again?
DarrenM
- chuahyenhuaMay 23, 2017Apprentice
Hi
Yup. the devices are working but the main point is that the Orbi should not automatically download the latest firmware without user intervention. The user should have the perogative to decide when to update.
regards
chris
- MarkC1024May 24, 2017Luminary
This appears to be corrected with the most recent update. Mine did not update until I logged into the router and told them to.
