jamepc's avatar
jamepc
Orbi Backhaul Ethernet Switch
Currently when I connect the RBS50 satelites via ethernet to a switch that has other devises, my network goes crazy. I loose Wifi on some devises and others I lose internet connection (but maintain local network conection).
I use an unmanaged Netgear switch but have other devises on the same switch. Do the staelites need their own switch? Or can other devises be on the switch too?
Thankyou,
Jamie
  • plemans's avatar
    Other devices can be on the switch. I've got quite a few on mine.
    What modem/gateway do you have?
    What firmware is on the orbi?
    what other devices are connected to the switch?
    What actual switch is it?
    How is your network wired up?
    for example see my signature.
  • FURRYe38's avatar
    How do you have the RBS and switch connected to the RBR?
    https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
    How long after you connect the RBS to the switch are you waiting for the RBS to sync fully?
    Thankyou,
    Jamie
  • CrimpOn's avatar
    CrimpOn
    jamepc wrote:
    Currently when I connect the RBS50 satelites via ethernet to a switch that has other devices, my network goes crazy. I loose Wifi on some devices and others I lose internet connection (but maintain local network conection).
    I use an unmanaged Netgear switch but have other devices on the same switch. Do the staelites need their own switch? Or can other devices be on the switch too?
    Is "currently" significant?  i.e. was this configuration working before?
    Yes, other devices can be on the same switch as the satellite.
    Is it correct to assume that the swtich comes after the Orbi, i.e.::
    Internet modem port connected to WAN (yellow) port on Orbi.
    Orbi LAN port connected to switch.
    Satellite and other devices connected to switch.
    • plemans's avatar
       If your vonage devices aren't connected, do you have issues with other devices connected?
      I've seen where some VOIP phone setups host their own dhcp server and it can cause issues.
