RBR20_user's avatar
RBR20_user
Orbi Blocking my IMAP server
I cannot connect to my email provider imap.onebox.com on any device on the wifi or LAN. I can ping it no problem. If i connect directly to cable modem i can retrieve emails on laptop. Same with phone if I turn off wifi and go cellular.
I have defaulted Orbi and power cycled cable modem to no avail.
I have also tried to add a service  via security>block services>allow>and added imap port 143.
also added https 443.
Firmware is current V2.3.5.26
 any ideas????
  • CrimpOn's avatar
    CrimpOn
    Opening a port is for when there is a host connected to the Orbi that should be available to access from the internet.  Orbi does not restrict connections to the internet.  I just checked my Orbi.  Not only can I "ping", but I can also connect to the IMAP server, which says that it is:
    C:\Users\xxx ping imap.onebox.com
    Pinging smtp.onebox.com [204.11.168.233] with 32 bytes of data
    Reply from 204.11.168.233: bytes=32 time=13ms TTL=243
    Reply from 204.11.168.233: bytes=32 time=12ms TTL=243
    Ping statistics for 204.11.168.233:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 12ms, Maximum = 13ms, Average = 12ms
    C:\Users\**bleep**>nslookup imap.onebox.com
    Server: UnKnown
    Address: fe80::a204:60ff:fe1c:239
    Non-authoritative answer:
    Address: 204.11.168.233
    Aliases: imap.onebox.com
    C:\Users\xxx telnet imap.onebox.com 143
    * OK securemail.onebox.com MailSite IMAP4 Server 10.3.0.2 ready
    What email application is being used, on what platform (Windows, Mac, Android?)
    Does this Orbi have Disney Circle or Bitdefender Armor activated?
    • RBR20_user's avatar
      RBR20_user
      hmmm
      Well i cannot telnet to imap.onebox.com behind the Orbi, just times out, but I am able to directly to cable modem
      The email clients are Outlood 2010 and Apple Mail Windows 10/7 and Apple OS 13.3.1
      The logs from
      C:\Users\xxxx>nslookup imap.onebox.com
      Server: dns.google
      Address: 8.8.8.8
      Server: cdns01.comcast.net
      Address: 75.75.75.75
      FROM BEHIND CABLE MODEM
      C:\Users\xxxx>telnet imap.onebox.com 143
      C:\Users\xxxx>ping imap.onebox.com
      Reply from 204.11.168.233: bytes=32 time=36ms TTL=243
      Reply from 204.11.168.233: bytes=32 time=38ms TTL=243
      Minimum = 36ms, Maximum = 38ms, Average = 37ms
  • FURRYe38's avatar
     any ideas????
      • FURRYe38's avatar
        Ok, just checking to be sure there is no router there. You should be good up and thru the Orbi router though.
