jeffbr26's avatar
jeffbr26
Follower
Dec 15, 2018
Orbi Blocking Websites - Solved
ORBI is blocking HTTPS websites that are not explicitly defined in URL.
To unblock any https website, do the following:
Log into to your router admin console (https://orbilogin.net)
Click on Advanced Tab
Click on Security >> Block Services
Click Add
Click on Service Type DropDown and Select HTTPS
Click Add to save
Your all set.  Close out admin and then retry ORBI admin console as just orbilogin.net and waalaa.Add Https as unblocked service
  • How do you perform this when Orbi is blocking access to the the login site? I switched networks, but then of course, I can't login into the router when I am not on the Orbi network. This issue is infuriating!!
    • FURRYe38's avatar
      You need to be on the same network as Orbi.
      Do you have two routers?
  • I can't even go to the Orbi login website without it blocking it for me. What am I doing wrong?
    • FURRYe38's avatar
      What do you mean by blocking it? You can't access the RBRs web page?
      Do you have Armor or Circle enabled?
      Try using a different web browser.
  • Hello Netgear!
    I have the RBR850, newest mesh system with 2 satellites.  I love it!   However, there are a few issues with blocking that I'd like to eliminate.  We're experiencing a temporary 'unavailable' status on some websites, and it takes 2 tries to get them to open up.  When they finally connect it doesn't specify the connection type.
    I followed the instructions to add the HTTPS and that helped.  There is a WHOLE list of possible 'Service Types' that could be added as well.  Are there any others that I could safely add to improve my connectivity?    I hope someone knows which of the types below are safe to add:
    ANY (UDP)
    AIM
    AGE OF EMPIRE
    BGP
    BOOTP CLIENT
    BOOTP SERVER
    CU-SEEME (7648)
    CU-SEEME (24032)
    DNS
    FINGER
    FTP
    HTTP
    HTTPS (already added)
    ICUII
    IDENT
    IP-PHONE
    IRC
    NET MEETING
    NFS
    NEWS
    QUAKELL
    RCMD
    REAL-AUDIO
    REXEC
    R LOGIN
    R TELNET
    RTSP
    SFTP
    SMTP
    SNMP
    SNMP TRAPS
    SQL NET
    SSH
    STRMWORKS
    TACACS
    TELNET
    TFP
    VDOLIV
    VPN-IP
    VPN-IPSEC
    VPN-L2TP
    PPTP
    Thank you!!
    • schumaku's avatar
      schumaku
      The new modern trend by the Web browser makers ot hide things - click into the broser URL line eg. behind the text and the protocol (typically https:// or rarely the http:// ) will show up.
      Very unlikley. If you block https (this is port 443/tcp) and http (port 80/tcp) virtually no usual web site would be reachable....
    • FURRYe38's avatar
      https://community.netgear.com/t5/Orbi/RBR50-Have-You-Installed-V2-7-2-104/td-p/2055212/jump-to/first-unread-message
      LinderB wrote:
      Hello Netgear!
      ANY (UDP)
      AIM
      AGE OF EMPIRE
      BGP
      BOOTP CLIENT
      BOOTP SERVER
      CU-SEEME (7648)
      CU-SEEME (24032)
      DNS
      FINGER
      FTP
      HTTP
      ICUII
      IDENT
      IP-PHONE
      IRC
      NET MEETING
      NFS
      NEWS
      QUAKELL
      RCMD
      REAL-AUDIO
      REXEC
      R LOGIN
      R TELNET
      RTSP
      SFTP
      SMTP
      SNMP
      SNMP TRAPS
      SQL NET
      SSH
      STRMWORKS
      TACACS
      TELNET
      TFP
      VDOLIV
      VPN-IP
      VPN-IPSEC
      VPN-L2TP
      PPTP
      Thank you!!
  • Retired_Member's avatar
    Retired_Member
    I followed the procedure but the default port number for all websites was 443. That doesn't seem right.  Plus, is this method bypassing security protocol and just allowing all websites through, regardless of their certificates, expired or not?
    Click Add
    Click Add to save
      Retired_Member
      That's strange how my Orbi RBR20 router did not produce the following error when trying to login by entering 192.168.1.1 into the browser and logged me in just fine for the longest time and then out of the blue I am no longer able to do this without changing a setting on my router to allow all https sites through. This seems very odd and incorrect. I sure hope this information is coming from an experienced networking and security professional at Netgear. You can't blame me for questioning it. While I'm inside the setting to block or allow services shouldn't I also add "DNS?" for all websites?  Where can I find clear instructions that explain the use of these different settings?
      Your connection is not private
      Attackers might be trying to steal your information from 192.168.1.1
  • Tried this, did not work for me. Are there any other solutions? I am attempting to log into my tv streaming service( which has worked previously) now the Orbi blocks it as soon as I attempt to enter a password. I unblock the site, but it still continues to block.
  • Right out of the box, I was getting the "your connection is not private" message on nearly every website I visited. After going through my account on orbilogin.com, I found that the problem was that the default date on my device was not updated. Under the advanced tab > Administration > NTP Settings, the current time showed January 20, 2021. When I clicked the Apply button, it connected with the Netgear NTP server and updated the current time to today's date / time. After this, now I am able to access all the websites without any issues.
