eric00998's avatar
eric00998
Orbi connects to R7000 for openvpn client
As Orbi do not support openvpn client, I plan to connect orbi with R7000. I found some ideas from below link.
https://community.netgear.com/t5/Orbi/Netgear-Nighthawk-R7000-and-Netgear-Orbi/td-p/1424315
I would like to know is there any configuration I need to pre-set in Orbi base and satellite
The R7000 wifi is closed. Should I configure the wifi setting in orbi base? Or I can simply connect a cable to orbi base and everything fine?
