Pauljm's avatar
Pauljm
Follower
Jul 01, 2018
Orbi constantly dropping internet and rebooting
My Orbi is dropping the internet connection and is rebooting itself every 20 minutes or so. Been working fine for 7 months and all of a sudden doesn’t anymore. Game factory reset multiple times but still the same issues. Would like my money back on this garbage and just get a normal router that will actual work. Sitting her using my cell phone data to post this cause nobody in the house can connect To the bleeping internet
  • I am having the same issue.  Thought it might be a firmware problem so I upgraded to v2.1.4.16 and still have the same issue.  It rebooted on my 3 times while i was on a Webex call.
  • FURRYe38's avatar
    For both posters:
    Any other wifi neighbors near by? If so, how many?
    What channels are you using? Try manual channels 1, 6 or 11 on 2.4Ghz and other unused channels on 5Ghz.
    Disable MIMO, Daisy Chain and Fast Roaming.
    Whats the distances between the router and satellites.
    What is the Mfr and model# of the ISP modem the Orbi is connected too? Built in router here by chance?
    Review this and try it out after a factory reset:
    https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1592753/highlight/true#M34020
  • I have 1 RBR50 router and 3 RBS50 satellites.  Everything is at firmware version 2.1.4.16
    My throughput testings is great.  In general, laptop and TV usage I have not noticed a problem.  But if I'm on a WebEX or bluejeans or skye, it is really bad.  I lose my ability to hear people or talk myself.  Video hangs, etc.  I also have a IP polycom phone and the thing is constanly every 30 mins or so rebooting itself because it can't find the network.
    I don't know what the problem is.  Maybe Orbi is rebooting itself.  Is there a log some where that tells you if it is rebooting?
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Yes there is a log its under Advanced-Administration-Logs also you may want to check your modem logs to make sure its not a issue on the ISP side.
      DarrenM
