gearnetxam
Sep 13, 2018Tutor
orbi constantly dropping internet
I consistently for the last many months had outages of my internet connection on the orbi network - in past it happened once or twice a week for a few minutes. enough to be annoying but not enough to...
edliu97
Sep 14, 2018Aspirant
I had recently bought RBK43 for a couple of days and experienced the same issue. The orbi kept dropped in internet connection few times a day.
Really felt annoyed.
Hope they will issue new firmware and tackle the issue.
Sep 14, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- edliu97Sep 14, 2018Aspirant
It was not working and getting worse after changed the setting.
The disconnection kept occur a few times in an hour. Really exhausted in dealing with this orbi.
It seemed there are huge problems in continuing connection the internet and the latest firmware has not addressed to this issue.
Hope they could address it quick and fast, otherwise other consumers will buy other brands instead of netgear
- FURRYe38Sep 14, 2018Guru - Experienced User
Please provide feeback to the questions presented so we can get a better idea of your situation and might be able to help you better.
Not everyone is having a bad experience with there Orib systems. However some it just takes some fiddling with or troubleshooting to get workign better. You also may have a bad system which may need to be RMAd. However we can't determine that untill we get more information and try a few things first. This problem maybe only with your system and not FW related.
There is a new beta FW available as well:
There are pleanty of other users that are having good experiences.
- gearnetxamSep 16, 2018Tutor
2.1.4.6
Swisscom, internet box plus, siligence, SGA441SW
What is the size of your home?2.5 stories
Sq Ft?
~160m2
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.from router to satalite near TV is approx 3 meters
from router to satellite on attic is approx 10 meters
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.i tried iterate all of them - no difference.
Any Wifi Neighbors near by? If so, how many?1 sometimes 2 but they don’t overlap/interfere afaik.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).made no difference. If anything it kinda got worse.
In the end I completely factory reset everything and i’ve Now been running for approx 2 days without noticeable problems.
This is though the same thing I do every now and then when internet connection starts dropping out or some other issue occurs. I still would like to understand why orbi thinks there is no internet when everything else can connect fine via the Swisscom router by a cable (or WiFi but i have that turned off on Swisscom to not interfere with orbi)
thank you
- ekhalilSep 16, 2018MasterAre you sure that your Swisscom modem is configured as a bridge and not a router?
Orbi is running in AP mode.
in any case why should bridge mode on modem matter if the connection works at all other times ? Curious to know.
- FURRYe38Sep 16, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.30 feet is recommended in between between router and satellite to begin with depending upon building materials.
2.1.4.6
Sq Ft?
~160m2
thank you
- cyberprashantSep 16, 2018Luminary
are you connecting anything to the ethernet ports? Try to not connect anything to the ORBI's (esp satellite) ethernet ports and see if that helps
